What Accessories Are Available for PXIe-6569?
Updated Dec 31, 2025
  • PXIe-6569
What are the available accessories and compatible components for NI PXIe-6569?
Below are the available accessories for PXIe-6569 that can be purchased from NI:
Part NumberDescriptionNotes
788259-01 
TB-6569, High Speed SEARAY to MiniSAS HD Breakout
Can be used together
788260-01MiniSAS HD Breakout Cable to SMA x16
787317-01SR240M-SR240M Cable, 1 Meter Will require terminal block as a breakout
787317-0R5SR240M-SR240M Cable, 0.5 Meters Will require terminal block as a breakout
