This error message indicates that DIAdem failed to load or process a specific file while running the script. It means DIAdem attempted to open a data file (for example, .raw, .ddt, or another supported format) but was unable to read or load it. Ensure that you have installed the correct DataPlugin for the file type and that the plugin is compatible with the operating system you are using.
