How to Add Timeout for General Teststand Step that is Calling Other Code Module & API
Updated Dec 22, 2025
  • TestStand
The customer is interested in how we can configure the Teststand step timeout, which is not available in normal step settings or properties.
Here are two methods for setting a timeout for steps in TestStand
Setting a timeout for all steps
  • Open TestStand and Click on Configure/Stations Options
  • Click on the Time Limits section, and you will see the set time limitsĀ
  • Enable Set a Time limit for this operation, and set the Time limit needed
  • This enables a timeout for all steps in the sequence.
  • When time expires, there are four actions: Prompt for action/Terminate Execution/Abort Execution/Kill the threads
Setting a timeout for specific steps
  • Open the sequence and click on the step you want to modify
  • Click the properties in the steps settings and choose expressions
  • Add the following to the pre-expression, and you can select the handling method according to needs
  • // Set a 5s time limit for the step before execution and chooseTerminate when timeout
    RunState.Engine.StationOptions.SetTimeLimitEnabled(TimeLimitType_NormalExecution, TimeLimitOperation_Executing, True),
    RunState.Engine.StationOptions.SetTimeLimitAction(TimeLimitType_NormalExecution, TimeLimitOperation_Executing, TimeLimitAction_Terminate),
    RunState.Engine.StationOptions.SetTimeLimit(TimeLimitType_NormalExecution, TimeLimitOperation_Executing, 5)
  • Add the following to the post-expression
  • Add below into Post-expression:
    // Set the time limit to false after the step execution
    RunState.Engine.StationOptions.SetTimeLimitEnabled(TimeLimitType_NormalExecution, TimeLimitOperation_Executing, False)
