Dimensions of Ettus LP0410 Antenna
Updated Jul 27, 2026
  • LP0410 PCB Antenna
What are the dimensions of the Ettus LP0410 antenna?
The physical dimensions of the Ettus LP0410 antenna are listed below:
- Base width: 11.3 inches (28.7 cm)
- Top width: 3.8 inches (9.7 cm)
- Length: 9.2 inches (23.3 cm)
- Thickness: 0.060 inches (1.524 mm)
- All dimensions are nominal and may vary slightly due to manufacturing tolerances.
- For applications with tight mechanical constraints, verify dimensions directly on the antenna.
