This is intended behavior in FlexLogger. The NI-9208 hardware always returns values in Amps, and FlexLogger uses a linear scale that defaults to 1 (e.g., 1 A/A).
When you change the display unit, FlexLogger updates the unit label but does not automatically scale the numeric value because it cannot assume the configuration or any attenuation/amplification circuits.
To display correct values in mA or µA, you need to configure the scale manually.
If your DUT is directly connected (no attenuation or amplification):
- For mA, set the scale to 1000 mA/A.
- For µA, set the scale to 1,000,000 µA/A.
Then you can verify that the Signal Range and alarm thresholds now reflect the correct magnitude (e.g., 18 mA instead of 0.018 mA).
