Refer to the steps below for the programming structure.
- Add an indicator for MSO Read VI status.
Insert a dummy indicator to monitor the status of the MSO Read VI. Initialize it by wiring a False constant to the indicator. - Implement timeout logic using a While loop.
Place a While Loop and include an Elapsed Time function inside it to serve as the timeout mechanism. - Create a Property Node for Status (Write Mode).
From the indicator created in Step 1, right-click and select: Create → Property Node → Value.
Wire this property node to the error cluster status after the MSO Read VI.
Change the property node to write by right-clicking and selecting Change All to Write. - Create another Property Node for Status (Read Mode)
Duplicate the property node from step 3, but keep this one in read mode.
Place it inside the While Loop and wire its output to an OR comparison together with the Elapsed Time condition. Connect this OR result to the Conditional Terminal of the While Loop. - Add a Case Structure for Closing MSO.
Insert a Case Structure after the loop. In the True case, place the MSO Close VI which is connected to the MSO Run VI. Leave the False case empty.
In theory, when a trigger signal is present, the MSO Read VI executes successfully, and the error cluster status updates accordingly. Conversely, if no trigger signal is detected, the MSO Read VI does not execute, leaving the status undefined. This behavior can be used to control the While Loop with an Elapsed Time function, ensuring the loop stops correctly if a trigger occurs within the specified timeout. However, if the loop does not terminate after receiving the trigger, the program will close abruptly because the elapsed time condition passes a True value to the MSO Close VI in the case structure. Therefore, it is essential to ensure the elapsed time logic stops before the timeout condition becomes True when a trigger signal is received.
