Negative Kelvin Values When Simulating a DAQ Temperature Input Device
Updated Dec 1, 2025
  • FlexLogger
  • NI-DAQ™mx
When simulating a DAQmx temperature input device, I am receiving unexpected negative Kelvin values in FlexLogger.
This is a normal behavior for temperature input modules, since the simulation doesn't model real analog behavior - it simply generates synthetic data. DAQmx uses a fixed, full-scale sine wave or predefined signal pattern that ignores user-defined input ranges or thermocouple limits. The "Min" and "Max" settings in this context serve only as metadata for scaling or display, not as active voltage constraints. Since there's no real sensor producing microvolt-level changes and no analog front end adjusting gain, the simulated readings stay consistent and predictable, reflecting nominal temperature trends rather than true hardware response.
