The following figure shows the essential fields of the standard and extended frame formats:Is it possible to manipulate the End of Frame section to make it shorter or longer? If not, can the time between each frame be manipulated?
The End of Frame cannot be manipulated since it's preprogrammed. Instead the following workatounds can be implemented to control the time between each transferred frame:
When the CAN:Transmit Time property is used within an NI-XNET output session, keep in mind that it is rounded to the nearest 500 µs increment (0.0005).
CAN Frames
