PXIe-430x modules support selectable digital filters with predefined cutoff frequencies. These filters are designed to provide anti-aliasing and noise reduction. However, the cutoff frequency cannot be arbitrarily set; it must match one of the supported values listed in the module’s datasheet.
For example, PXIe-4304 and PXIe-4305 support the following cutoff frequencies:
Attempting to configure a value outside this range (e.g., 50 Hz) will result in a LabVIEW error. To avoid errors use only the supported cutoff frequencies listed in the module’s specifications.
