When plotting data in DIAdem using a 2D axis system, you might encounter a situation where the curve does not appear even though the dataset has been loaded successfully. This issue usually arises when the data format does not meet DIAdem’s visualization requirements. For instance, if the channel is stored in an incompatible time format, the curve cannot be displayed as expected. Below is an example of a time format that prevents the curve from being loaded:
