Step 1: Open the Command Prompt
- Press Windows + R to open the Run dialog.
- Type
cmd and press Enter.
Alternatively:
- Click Start, type Command Prompt, and select it from the search results.
- For administrative privileges, right-click Command Prompt and choose Run as administrator.
Step 2: Run the Sequence and Close SeqEdit.exe
Use the following command in the Command Prompt:
start /wait SeqEdit.exe /run MainSequence "C:\Users\Public\Documents\National Instruments\TestStand 2023 (64-bit)\Examples\Demos\Computer Motherboard Test\LabVIEW\Computer Motherboard Test Sequence.seq" /quit
Explanation of Command Components
start /wait
Launches a program and waits for it to finish before returning control to the command prompt.
SeqEdit.exe
The executable for the TestStand Sequence Editor.
/run MainSequence
Runs the sequence named MainSequence, typically the default entry point.
Full path to the sequence file. Use quotes if the path contains spaces.
/quit
Closes the Sequence Editor after the sequence finishes running.
