- When updating the firmware of a CompactRIO (cRIO) controller to the latest version in NI MAX, I encounter the following error message:
Error 80040390: There was a problem updating the firmware for this device
In some cases, repeated attempts appear to start the update process, but the device remains stuck on the message:
Transferring firmware image
The update does not complete successfully. How can I resolve this issue?
- When I try to update the firmware of my CompactRIO (cRIO) controller to the latest version using the Hardware Configuration Utility, I'm getting the error:
Failed to update firmware. Exception of type 'NationalInstruments.SystemConfiguration.SystemConfigurationException'
My cRIO is brand new but it comes with an older version of firmware and this error is not allowing me to upgrade to the latest version. How can I resolve this issue?
