Exclude Nigel During LabVIEW or TestStand Installation
During the LabVIEW installation process, users can opt-out of installing the Nigel package by deselecting NI Nigel AI for LabVIEW 20xx and NI Nigel AI for TestStand 20xx from the list of components. This is the simplest way to prevent Nigel from being deployed.
Note: To enable Nigel if previously disabled using this method, re-run the LabVIEW installer and select NI Nigel AI for LabVIEW to enable the Nigel component. There is no need to reinstall the full LabVIEW suite.
Disable Nigel via Registry Keys
IT administrators can disable Nigel across systems using registry keys. These keys are documented in the Nigel™ AI section of the LabVIEW User Manual and include:
- Disable Discuss Feature — Prevents access to collaborative discussion tools.
- Disable All Nigel Functionality — Ensures Nigel is inactive, even if installed.
Note: This method is supported beginning with Nigel™ AI for LabVIEW 2025 Q3 Patch 2 and Nigel™ AI for TestStand 2025 Q3 or newer. Refer to the Nigel™ AI section of the LabVIEW User Manual linked above.
Block All Browser Traffic to Nigel Webpage
Nigel communicates through a dedicated URL endpoint. To effectively disable Nigel’s online functionality, you can block all network traffic to the following URL: https://tnm.emerson.com/nigel
Blocking access to this endpoint will prevent Nigel from operating online. For assistance with implementing this block, please contact your IT Support team.
Note: Ensure this method aligns with your organization’s network policies and firewall configurations.
License File Configuration via Renewals Team
For organizations with elevated concerns, NI’s Renewals team can generate license files based on LabVIEW versions released prior to 2025 Q3, which do not include Nigel.
The LabVIEW 2025 Q3 release includes core performance optimizations, expanded integration support, and other enhancements beyond Nigel. Skipping this version may introduce compatibility constraints with newer NI tools and limit access to critical updates.
