What is the reason about wrong response when customer move or copy the local variable or control in LabVIEW ?
Updated Nov 28, 2025
When you used the local variables and controls in LabVIEW , you can often move them in new position or copy them to create new ones ; Sometimes , some customer discovered a strange issue with LabVIEW: after creating a local variable, moving or deleting it also caused the original control to change accordingly ; Whats is the reason ?
This suggests that LabVIEW might conflict with certain software, or as some online sources claim, "due to reasons like resource allocation or other factors." Therefore, it's advisable to close certain programs before trying again; For example , someone found that LabVIEW and Youdao Dictionary open simultaneously, and noticed the similar problem; And one customer also reported the same issue when customer used the LabVIEW and other AI tools. After closed the certain software , the problem was fixed ;
