Is the sequence-based approach officially supported to achieve a 100ms pulse on PXIe-4133?
Updated Nov 26, 2025
  • PXIe-4133
We are using a PXIe-4133 and need to generate a pulsed current waveform of 10 mA for 100 ms.
However, the maximum supported pulse width on the PXIe-4133 is 655 µs.
After reviewing the specifications, it appears that a dead time of zero (100% duty cycle) can be configured.
Therefore, we propose an alternative approach:
Using a 100% duty cycle 10 mA pulse with pulseWidth=50us repeated across 2,000 elements to achieve a total duration of 100 ms.
(2,000 × 50 µs)
Is this sequence-based method officially supported for achieving a 100 ms pulse on the PXIe-4133?
Yes, as long as the driver does not return an error, this approach is supported.
The driver includes built-in validation to ensure that the pulse sequence does not exceed thermal limits.
Additionally, it automatically inserts a thermal cooldown period after the sequence to prevent heat buildup within the unit.
Please note that this cooldown period may affect how frequently the PXIe-4133 can generate the requested 10mA pulse for 100ms.
