The issue occurs because the PXIe-1090 chassis has a limited current capacity on the -12V rail, specifically:
PXIe-1090 provides only 250 mA on the -12V rail.
The PXI-5122 digitizer draws up to 270 mA from the -12V rail, exceeding the chassis limit.
This mismatch causes:
- The chassis to fail to fully initialize the PXI-5122 module.
- The System LED to turn red (indicating a fault).
- The MXI link LED to turn off.
