The VeriStand Operation License can be used for versions of VeriStand up to the year in which the license was purchased. If you wish to use it with versions of VeriStand released after the purchase year, an update of the support service (SSP) is required.
Therefore, for example, if you purchased the VeriStand Operation License at the 2023 version and did not update the support service, you would not be able to use it with VeriStand 2025.
