The NI-Digital driver allows TDR (Time Domain Reflectometry) offset values between 0 and 80 nanoseconds.
This means when configuring TDR offset in the Digital Pattern Editor (DPE), you can set the value anywhere within this range.
TDR measures the latency introduced by your setup, and applies the measured values to the channels you select to ensure accurate measurements.
