1. Check Your Licensing and Entitlement
Before installing or accessing Nigel, please kindly make sure you meet the following requirements to access Nigel:
1.1 Product Eligibility:
- LabVIEW Professional Development System 2025 Q3 or later (Windows only)
- TestStand Development System 2025 Q3 or later
- LabVIEW+ Suite 2025 Q3
- EA, VLA, or Partner Suite containing LabVIEW or TestStand
1.2 Entitlement Requirements:
- Active Software Service Program (SSP) Entitlement: Required for Nigel access.
- Academic Licenses:
- Single-seat academic licenses and Student Install Option (SIO) licenses do not include SSP by default and do not have access for Nigel.
- Academic Volume License (AVL) holders may qualify if SSP is included and only user who is registered as technical contact will have access to Nigel. Technical Support Access for Academic Volume Licenses (AVL)
- Partner Software Subscription:
- Nigel is accessible if the subscription is active.
- Ensure the SN is registered in your NI.com account. Kindly refer to Registering a Product for more details.
2. Link Your Serial Number and Verify Entitlement
- Log in to your NI User Account.
- Go to “View My Products” under Products and Services.
- Register your serial number (from purchase confirmation, NI License Manager, or your administrator).
- Your entitlement should appear within 24 hours.
- If you are an academic volume license user, ensure you are listed as a technical contact.
3. Download, Install, and Activate LabVIEW or TestStand
- Visit the NI downloads page Software and Driver Downloads and install the software needed.
- Download and install LabVIEW Professional or TestStand Development System 2025 Q3 or newer.
- Activate your software using your NI User Account by referring to How to Access the NI Nigel™ AI.
Note: Nigel is only available in LabVIEW Professional and TestStand Development System 2025 Q3 or later (both 32-bit and 64-bit LabVIEW versions - Supported LabVIEW Bit Versions for Nigel). Community Edition, Base, and Full do not support Nigel.
4. Log In to NI Nigel™ AI
- Open the NI Nigel AI application.
- Click “Log in” and sign in using your NI User Account.
- Authorize access if prompted.
Security Note: Nigel uses Auth0 for secure authentication. Your credentials are protected with industry-standard encryption and authentication protocols.
5. Troubleshooting Nigel Access and Login Issues
If you encounter issues accessing or using Nigel, follow these steps:
Common Issues
- Nigel crashes when opened from LabVIEW or TestStand.
- Blank screen or login errors.
- Error 403 (Forbidden) when using 'Search with Nigel'.
- Activation issues with academic or partner licenses.
- Authorization error when logging in.
5.2 Login Issues:
- Update to Nigel AI Integration 2025 Q3 Patch 3 or newer via the Updates tab or manual install as shown in How to Update the Nigel AI for Log In Issues.
- Uninstall and reinstall LabVIEW/TestStand, ensuring Nigel is included in the additional items.
- Delete corrupted local store file (C:\Users\<username>\AppData\Local\National Instruments\NigelLocalService\ProtectedStore.dat) if it exists.
- Restart your machine.
- Confirm plugins are installed at C:\Program Files\National Instruments\Shared\NigelLocalService\plugins.
- To ensure proper access to Nigel, verify that your PC’s firewall allows the following NI URLs and ports:
- delta.ni.com on port 443
- download.ni.com on port 80
- ni.com on port 80
5.2.1 If you experience the following Authorization Error message when logging in to Nigel.
You are not authorized to connect to the Nigel AI. Please contact your administrator.
- To get rid of this error, make sure you are an end user.
- To check if you are an end user go to the My Products Page on your NI User Account, it will be visible as registered as an end user.
5.2.2 If you are experiencing an error:
Error starting gRPC service...
5.2.3 If you continue to experience connectivity issues, try disconnecting your system from the internet, rebooting, and then reconnecting to refresh the network connection.
5.3 Contact Methods
If the above solutions do not resolve the issue:
- Create a Technical Support case and gather Nigel logs located at %programdata%\National Instruments\AIAssistants\Logs\. Alternatively, you can contact Technical Support at +1 866 275 6964.
- Create a Get Account Help case if the issue is related to difficulties logging in to your NI User Account.
