Use NI Nigel™ AI to Run a TestStand Sequence
Updated Aug 7, 2026
  • TestStand
  • Nigel AI Integration
This article shows you how to use NI Nigel™ AI in NI TestStand 2025 Q3 or later, to run test sequences using natural language commands. By following the steps, you'll learn how to simplify test execution, reduce manual effort, and save time. With intuitive prompts, Nigel™ makes it easy to initiate and control test sequences, streamlining both basic and advanced testing workflows.
For the following example you are going to require TestStand 2025 Q3 with Nigel™ AI or later and the example sequence called Computer Motherboard Test Sequence.seq:
  1. Open the TestStand application. Make sure you're using TestStand 2025 Q3 or later.
  2. Load the sequence file you want to run. In this example, it uses Computer Motherboard Test Sequence.seq, you can find the TestStand Example Programs in this link.
  3. Locate the Nigel™ AI Button, click the Nigel™ AI button in the toolbar to open the assistant panel. You will find the Nigel™ AI on the right side of your TestStand.
  1. Log In to Nigel™ AI, you can follow this link on How to Access the Nigel™ AI.
  2. At the Nigel™ AI enter a prompt to run the test, you can enter command like run single pass. Nigel™ AI will interpret the prompt and prepare the sequence for execution.
  1. Click the Run active sequence file button. Nigel™ AI will start the test run.
Result when Nigel™ AI start to run the Sigle Pass test in TestStand.
