When using the PXI-5124 digitizer, NI MAX displays the following error message:
Error -200551: Hardware clocking error occurredÂ
How can I solve this error?
Try a Different Chassis or Slot:
Install the PXI-5124 in another PXI chassis or a different slot to rule out a backplane clock or chassis issue.
Check for Hardware Damage:
Inspect the digitizer for any visible damage or bent connectors.
Ensure the module is securely seated in the slot.
Contact NI Support:
If the problem persists after testing with a different chassis or slot, the PXI-5124 may be damaged.
Contact National Instruments (NI) Technical Support for further troubleshooting or repair options.
