Flash ECU Through CAN Interface
Updated Oct 31, 2025
  • NI-CAN
I need to flash a device via CAN, similar to using a PEAK or Vector tool. I want to know if NI provides a program or tool that can perform ECU flashing over CAN.
Currently, we don't provide any example codes for flashing with NI-XNET. However, it is possible to write a LabVIEW code that will implement the functionality.
You can find examples and suggestions in the NI Community forums. Some useful threads can be found in the Related Links section of this article.
