PXIe-6593 Digital I/O Connector Output
Updated Dec 18, 2025
  • PXIe-6593
The specifications of the PXIe-6593 module state the following:
ConnectorMolex™ Nano-Pitch I/O™
5.0 V Power±5%, 50 mA maximum, nominal
What does this mean?
The 5 V pin on the connector is generated by an on-board charge-pump supply, regulated to ±5 %. It is designed to provide up to 50 mA total output current for light external biasing or logic reference purposes. Short inrush currents up to approximately 100 mA are tolerated, but continuous loading beyond 50 mA should be avoided.
