The VST Self Calibrate utility (located in the directory C:\Program Files (x86)\National Instruments\NI VST\Self Calibration) was built for the first generation of NI Vector Signal Transceivers (i.e. PXIe-564x VSTs). This utility performs a self-calibration on the PXIe-564x VSTs using the VST Instrument Design Libraries (IDLs) that are only supported with those VST models. Under the hood of the VST Self Calibrate utility, it performs a model number query of the devices in the chassis and will only populate the VST in the list of available resources if the device model is a 564x.
For all other VSTs, including the 564x VSTs, the recommended self-calibration methods are:
- Using the Hardware Configuration Utility (HWCU)
- Using the NI-RFSA/RFSG API
- Using the NI-RFSA/RFSG Classic Soft Front Panel (Not supported with the PXIe-5842 or PXIe-5860)
- Using InstrumentStudio (Requires RFmx to be installed)
