Windows does not support launching GUI-based applications (like SeqEdit.exe) directly via SSH. Attempting to run .bat files that invoke TestStand sequences fails silently when triggered remotely. Use Windows Task Scheduler to run a batch file that launches the TestStand sequence. Trigger the scheduled task remotely via SSH:
1. Create a Batch File
Create a .bat file that launches your TestStand sequence:
"C:\Program Files\National Instruments\TestStand 2021\Bin\SeqEdit.exe" "C:\Path\To\YourSequence.seq"
2. Set Up a Scheduled Task
- Open Task Scheduler on the target Windows PC.
- Create a new task:
- Action: Run the batch file.
- Trigger: Manual (no schedule needed).
- Run with highest privileges.
- Configure for: Windows 10 or later.
3. Trigger the Task via SSH
From the remote machine (e.g., Linux Bench PC), use:
schtasks /run /tn "YourTaskName"
