How to Replace Elements Inside a Cluster Programmatically Using VI Scripting in LabVIEW?
Updated Dec 18, 2025
This article explains how to programmatically replace an element inside a cluster in LabVIEW using VI Scripting. This method allows you to automate front panel and block diagram modifications, which is especially useful for tool development or dynamic VI generation.
Before using VI Scripting, you must enable it in your LabVIEW environment.
How to Enable VI Scripting
  1. Open your LabVIEW configuration file (LabVIEW.ini) and add the following line:
    EnableScripting=True
  2. Launch LabVIEW.
  3. Go to Tools>>Options.
  4. In the left pane, select VI Server.
  5. Check the box for VI Scripting and click OK.
  6. Restart LabVIEW.
Steps to Replace a Cluster Element Programmatically
  1. First, use the Open VI Reference function to obtain a reference to the target VI by specifying its file path.
  2. Then, use Panel property node to access the front panel of that VI.
  3. To retrieve the array of all controls present on the front panel , use the Controls[] property node.
  4. From this array, use the Index Array function to select the cluster control. To work with it as a cluster, cast the control reference using To More Specific Class.
  5. Once you have the cluster reference, use another  Controls[] property node inside the cluster.
  6. Then, use Index Array again to select the specific element you want to replace by specifying its index within the cluster.
  7. Finally, use an Invoke Node with the Replace method to replace the selected element with a new one. This approach allows you to programmatically replace an element without deleting and recreating it manually.
