Can Temperature Input Modules Take Standard AI Voltage Measurements?
Updated Jul 14, 2026
I want to take measurements with a C Series temperature input module, but I want to measure raw voltage without converting it into temperature. Which modules can do this?
Some temperature input modules can make an AI voltage measurement without converting the measurement into a temperature. However, the modules are optimized for temperature measurements and has a limited range for other types of applications.
Temperature modules that can take voltage measurements are:
  • NI-9210
  • NI-9211
  • NI-9212
  • NI-9213
  • NI-9214
Not all temperature modules can take voltage measurements. For example,  Resistance Temperature Diode (RTD) measurement modules cannot take voltage measurements.
The following modules cannot take voltage measurements:
  • NI-9216
  • NI-9217
  • NI-9226
If you want to check what types of measurements a module can do before purchasing, you can Create Simulated NI-DAQmx Devices in NI MAX, and then you can see what options are available when you Create Tasks for NI-DAQmx Devices in NI MAX.
