I am using LabVIEW I am executing the following step to set a custom shortcut for Navigation Window function.
- Select Tools >> Options >> Menu Shortcuts
- Select View >> Navigation Window
- Set the shortcut to Ctrl+Shift+N
- Click the Set button
- Click the OK button
- Exit LabVIEW
- After restarting LabVIEW, repeat steps 1) to 3)
At this point, the shortcut is not saved.
It is inconvenient to have to repeat the same settings every time LabVIEW starts, and clearly the behavior is different from previous versions.
Please let me know how to save the shortcut settings.
