Error Target Resource Does Not Match When Compiling LabVIEW FPGA VI
Updated Oct 15, 2025
When compiling the FPGA for the cRIO-9045, an error message appears stating:
You cannot run this VI because the target resources does not match the actual type of device.
Could you please advise on how to resolve this issue?
This error occurs because the IP address of the target specified in the LabVIEW project does not match the actual target as shown in NI MAX. To resolve this issue, re-add the correct target in the LabVIEW project and move the FPGA VI to the correct target.
