FieldDAQ devices typically consume more power than cDAQ systems because they integrate both the DAQ backend and I/O modules into a single ruggedized unit. Conceptually, a FieldDAQ can be thought of as equivalent to a cDAQ chassis plus two c-series modules. This integration results in higher overall power consumption, though not drastically so.
One key example is the FD-11637, which includes high-power excitation circuitry internally. In contrast, a comparable c-series module like the NI-9237 requires an external power supply to deliver similar excitation power. This built-in capability contributes to the higher power draw of FieldDAQ units.
