Upon using the field upgrade kit from Windows 7 to Windows 10 that I recently purchased 787535-03, I attempted to upgrade the OS of the PXIe-8840 with BIOS version 2.0.2f0 based on guidance from this KB link.
However, the following error occurred, and the upgrade could not be completed:
The install.wim file itself was found in the following folder:
D:\OS\WIMFiles\MUI\amd64\22H2\20230531
I ran Setup.exe directly from the USB drive.
Then I followed the steps from this KB link again, but the following options appeared in step 5. Select the USB drive as the boot option.
I tried selecting each option, but it just took me to the login screen instead of proceeding to step 6.
- P0:CT250MX500SSD1
- Dynabookdynabook USB DRVPMAP
- UEFI:dynabookdynabook USB DRVPMAP
- UEFI:dynabookdynabook USB DRVPMAP, Partition 1
