The SCB-68 has both hardware switch and software configuration components:
- Hardware Switches:
The SCB-68 is configured using physical switches.
When replacing the unit, you should ensure the switch positions on the new SCB-68 match the original.
Incorrect switch settings can cause the SCB-68 to appear malfunctioning.
Refer to Using the SCB-68 with Multifunction I/O Devices for more details. - Software Configuration:
The SCB-68 supports a temperature sensor that requires configuration in NI MAX or the Hardware Configuration Utility.
You can select the connected X Series or M Series device and configure its cabled accessory as an SCB-68 to enable DAQmx to use the onboard temperature sensor.
If the software configuration was already correct and the new SCB-68 has the same switch positions, no changes are needed in the software configuration.
