Error 6001 When Deploying a VeriStand Project Using the FPGA Add-On
Updated Nov 28, 2025
  • VeriStand Custom Devices
  • LabVIEW FPGA Module
  • VeriStand 2020 R6
  • LabVIEW 2020
I have a LabVIEW-built FPGA bitfile that is deploying to VS through the FPGA addon. When Scalar IO is added to the Custom Device, the deployment shows the following error:
NI VeriStand: Error occurred at the following location: "Targets/Controller/Custom Devices/FPGA Addon" Error 6001 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi This error code is undefined ...
Have I configured something wrong in my VeriStand project?
This occurs because the session reference of the custom device is lost if no scalar inputs are included. This is a known issue, fixed in the FPGA Addon Custom Device 23.0.0 (2023 Q1) version. If upgrading the custom device is not feasible you can add a scalar input to the project and the error will go away.
