The PXIe-4309 is equipped with 8 independent ADCs, each capable of supporting up to 4 channels in scan mode.
For measurements involving up to 8 channels, one ADC is allocated for each channel. However, for measurements involving 9 or more channels, a single ADC is used to handle two or more channels.When only one channel per ADC is used, multiplexing is not necessary. For example, when sampling is requested at 100 kS/s, the ADC operates internally at a rate of 2 MS/s, which allows for approximately 20 times oversampling, improving RMS noise performance through averaging and digital filtering.
However, when two channels share the same ADC, the ADC must multiplex between them. This means that each channel effectively receives 1 MS/s from the internal ADC, and when accounting for settling time and overhead, the effective oversampling per channel drops to less than 10 times. As a result, RMS noise increases compared to when there is one channel per ADC, even if the same sample rate is requested.
