Yes, it is possible to automate FlexLogger using TestStand. To enable this integration, you must first install the FlexLogger Plug-In Development Kit. Once installed, you will notice that TestStand includes a FlexLogger step type, which allows you to incorporate FlexLogger actions into your TestStand sequences.
Starting from FlexLogger 2025 Q1, NI have extend the functionality of FlexLogger with the FlexLogger step in TestStand
To help you get started, refer to the example programs below that demonstrate how to automate FlexLogger using TestStand.
C:\Users\Public\Documents\National Instruments\TestStand 20XX\Examples\FlexLogger
