RFmx Is Not Reporting Warnings on Subsequent Runs in .NET/C#
Updated Sep 17, 2025
  • RFmx
Programming Language
  • C# .NET
One the first run of my RFmx application in C#, it will report warnings as expected (such as an ADC Overload warning). On subsequent runs, it does not report the warnings. If I attempt to run the same code in LabVIEW, then the warning is shown each run as expected.
Is there a modification required in the way a warning query is done in the C# code?
RFmx .NET don't have event subscription mechanism for warning. Warning code will be returned as a status code from method.
As per the design, GetWarning method will clear the warning message after retrieving. You can use GetErrorString method instead to read the warning/error message without being cleared.
You can follow the below approach to effectively capture all warnings.
public string checkWarning(int code)
            string warningMsg = "";
            if (code > 0) //Read the warning
                instrSession.GetErrorString(code, out warningMsg);
                return warningMsg;
            return warningMsg;
Then, for all APIs for which you are interested to capture the warning message, you can call the API like:
checkWarning(Initiate),
checkWarning(WaitForMeasurementComplete),
checkWarning(FetchIQ),
etc.,
