VeriStand Steps for TestStand Real-Time Sequence Path Dropdown is Not Populating Correctly
Updated Sep 11, 2025
  • VeriStand
  • TestStand
Using the VeriStand Steps for TestStand, the Run Real-Time Sequence step drop-down does not populate with Real-Time Sequence to select even if the VeriStand project has sequences associated with it.  Why can this be happening?
This behavior will typically happen if you are using the VeriStand Steps for TestStand without first calling the project using the Open VeriStand Project step type.
There are examples showing how to properly use these step types at the following file path:
C:\Users\Public\Documents\National Instruments\TestStand 20xx (xx-bit)\Examples\VeriStand
