Unfortunately, there is currently no direct alternative available for LabVIEW 2025 Q3 as LabVIEW 2025 Q3 no longer supports the XNode-based “Discrete Transfer Function” block. To use this functionality, you must manually recreate the discrete transfer function using standard LabVIEW blocks such as shift registers, feedback nodes, and mathematical operations.
If you are using LabVIEW 2022 Q3 or earlier, you can still access the Discrete Transfer Function.vi from the Control Design and Simulation Module Toolkit, which provides similar functionality without relying on XNodes.
