Exporting Ref Out From Pps In Port On Usrp X410 Using Uhd Python
Updated Apr 29, 2026
  • Ettus USRP X410
Programming Language
  • Python
The USRP X410 includes a PPS IN connector that is primarily intended for accepting an external pulse‑per‑second (PPS) signal. However, this port can also be configured to output a reference clock signal (Ref Out). This capability is useful when synchronizing other USRPs or external equipment using the X410 as a clock source.
Follow these steps to enable Ref Out on the PPS IN port of a USRP X410.
1. Import the UHD Python Module
Ensure UHD is installed on your system and import the uhd module in Python.
import uhd
2. Create a USRP X410 Object
Instantiate a MultiUSRP object using the address of your USRP X410.
args = "type=x4xx, addr=<USRP IP ADDRESS>"
usrp = uhd.usrp.MultiUSRP(args)
Replace the USRP IP ADDRESS with the address assigned to your device.
3. Enable the Reference Clock Output
Configure the device to output the reference clock through the PPS IN port.
usrp.set_clock_source_out(1)
This call enables the reference clock output, allowing the PPS IN port to function as a clock output instead of an input.
