The inconsistency in numeric formatting between ATML reports and database logs in TestStand is caused by how the NumericFormat property is applied to numeric PropertyObjects. This property, if set, overrides the default formatting defined in the Report Options dialog and directly affects how numeric values are rendered in ATML reports. In contrast, the database plugin does not apply this property when storing values in the DATA column, though it may log the format string in the DISPLAY_FORMAT column.
Additionally, note that in the default TestStand database schemas, PROP_RESULT.DATA stores numeric values as strings with high precision, independent of NumericFormat.
To ensure consistent numeric formatting across both ATML and database outputs, users can follow these best practices:
- Avoid setting
NumericFormat on individual variables unless specific formatting is required. These overrides can be difficult to trace and may lead to unexpected results. - Use the Report Options callback to define a global numeric format:
- For ATML reports, configure the plugin to use a consistent high-precision format:
- Set
ModelPlugin.PluginSpecific.Options.NumericFormat = "%$.15g"
- Remove conflicting format settings before report generation:
- Traverse the
MainSequenceResults tree and clear the NumericFormat property from all numeric PropertyObjects by setting it to an empty string.
- Understand plugin behavior:
- The ATML plugin uses
NumericFormat if present; otherwise, it defaults to the global setting. - The database plugin stores numeric values with high precision regardless of
NumericFormat, but may log the format string separately.
- Log values as numbers, not strings
By applying some of these steps, users can maintain consistent numeric formatting across different report types and avoid precision loss or formatting discrepancies.
