This frame indicates the panel size that will be displayed when the VI runs. To remove this border, disable the option Scroll panes to origin at run time, which removes the panel boundary from the front panel.
This option is located under File>VI Properties>Window Run-Time Position as shown below.
When Scroll panes to origin at run time is unchecked, the frame does not appear.
