I am looking at the product page of PXIe-4330, PXIe-4331, PXIe-4339, PXIe 4340, or PXIe-4353 on ni.com. I would like to also purchase the terminal interface for these modules, but under Select required accessories section of the product page, the terminal models are either not listed or only the rackmount option is listed.
I understand that there are terminal interface such as TB-4300 exists for PXIe-4300, which uses the same 96-pin connector on the module front panel (image below). Are there similar terminal interface for the abovementioned modules?
