No, this type of conversion is not possible directly within TestStand. TestStand does not support direct conversion of a hexadecimal or integer bit pattern into a floating-point number using its expression language. While basic type conversions (e.g., Val("True") → 1.0) are supported, TestStand lacks capabilities such as:
- Bitwise operations (e.g., shifts, masks)
- Memory reinterpretation (e.g., treating a UInt32 as a Float32)
As a result, values like 0x4379E666 cannot be interpreted as 249.7999878 within a TestStand expression. To perform this conversion, use an external code module such as LabVIEW, C/C++, or Python to reinterpret the bit pattern as a floating-point number. Once converted, you can return the result to TestStand for display or further processing.
