The root cause for this error is often a wrong user input. So, the UHD driver currently reports this generic message. The fix mentioned below provides a better error message that explains what exactly was invalid.
This is fixed in UHD V_4.9, and you will get a better error handling on wrong user input, but you need to compile the code at your own. Installers are available with the UHD V_4.9 release. You can find the solution under the link below:
uhd: Remove usage of std::stoul() on user input · EttusResearch/uhd@a5b52c6
Recommendations
- Always run only one UHD application at a time
- Double check your input parameters for potential bad values (maybe you have a script, what changes inputs dynamically and in some corner cases those inputs are wrong)
