Instrument Studio allows you to monitor a DMM (Digital MultiMeter) measurement without disrupting other measurements, for example, a test sequence created in TestStand. Is there any way to do this with LabVIEW or another programming language? When I try to monitor using a LabVIEW example, it will stop my existing measurement.
From the NI Digital Multimeters user manual:
"When you install NI‑DMM, you can monitor, control, and record measurements from supported devices using InstrumentStudio."
