I built an executable from a LabVIEW VI and opened it from a third-party application or from a Windows Command Prompt. Upon running the EXE, a popup displays with the message "The file <file path of the EXE> could not be opened. No application was found to open that type of file." However, when I press the OK button of the popup window, the EXE runs normally. Why does this popup window get displayed? How can I set LabVIEW not to display this popup?
