If an error occurs on the niDCPwer Commit.vi, the voltage level/limit cannot exceed +-42.4 V if the Sequence Step Delta Time Enabled is set to True.
The voltage level/limit is 42.4 V if the Sequence Step Delta Time Enabled property is True. To use 60V, this property value has to be set to False.
