You can use a DIAdem VBScript to define specific colors for channels in a 2D curve chart. The following example script shows how to add curves to a 2D display and assign fixed colors:
Dim oMyArea, oMyCurve
'Get the active area of the current sheet
Set oMyArea = View.ActiveSheet.ActiveArea
'Set the display type to 2D curve chart
oMyArea.DisplayObjType = "CurveChart2D"
'Add curve for Time vs. Speed and set color to green
Set oMyCurve = oMyArea.DisplayObj.Curves2D.Add("Time","Speed")
oMyCurve.Color = "green"
'Add curve for Time vs. RPM and set color to blue
Set oMyCurve = oMyArea.DisplayObj.Curves2D.Add("Time","RPM")
oMyCurve.Color = "blue"
'Add curve for Time vs. Torque and set color to red
Set oMyCurve = oMyArea.DisplayObj.Curves2D.Add("Time","Torque")
oMyCurve.Color = "red"
When you run this script, DIAdem will automatically plot the selected channels (Speed, RPM, and Torque) against Time, and each curve will always appear in the color you assigned.
