The DUT sends XCP data on three event channels: 0x6AD, 0x6AE, 0x6AF. But the ECU Measurement and Calibration toolkit on XCP implementation currently does not support measuring variables with different DAQ_CAN_IDs(event channels) in DAQ List mode. XCP Master only supports a single DTO_ID for all measurements.
Recommendation: Use CCP protocol if ECU supports, as it already has the required multi-DAQ-List infrastructure for handling different event-channel CAN IDs.
