The pins on the XJ4 connector on the rear of any SLSC card go from A at the bottom of the connector to F at the top. The pins on the JH1 connector on a Rear Transition Interface (RTI) go from 1 at the bottom-right to 6 at the top-left.
For RTIs and SLSC cards that have 8 pins on the XJ4 and JH1 connectors, the pin mappings would be A-I and 1-8, respectively, but would follow the same pattern as the SLSC-12202 and RIT-12308.
The signals on the SLSC-12202 could be mapped as follows:
| SLSC-12202 Signal | XJ4 Connector Pin | JH1 Connector Pin | RTI-12308 Signal |
| Vsup_0 | F | 6 | V1+ |
| COM | E | 3 | V1- |
| Vsup_1 | D | 5 | V2+ |
| COM | C | 2 | V2- |
| No Connection | B | 4 | V3+ |
| NC Connection | A | 1 | V3- |
